does anyone know if fushion channel that we will be broadcasting in HD?Thanks
Does anyone really care??
Can't recall seeing that in the press release for upcoming (HD) but at this point who knows what spring might bringdoes anyone know if fushion channel that we will be broadcasting in HD?Thanks
Leslie doesn't want Dish messing with its Nielsen ratings.Yes??
Does anyone really care??![]()
I'd watch a program on fusion power, but not a whole network.![]()
I think it would be a challenge to find a single program on any Dish channel that talks (much) about fusion power.
Maybe Science every once in a long while. Fusion is the future though. Power from Fusion is about 50 years out from now, as it has been for a while.I think it would be a challenge to find a single program on any Dish channel that talks (much) about fusion power.
Spring goes until almost the end of May too....![]()
No not the same. Cable is not Internet. If you say it is, then so is Satellite. Both Cable and Satellite may make programming available over the internet, but to watch Cable (or Satellite) does not depend on or use the Internet. You may be missing the big step that DISH and Disney are making.
no i don't work for dish.
Haha ! I had to look it up actually and turns out there are 3-4 different versions of "spring" (or seasons) !You must be in a different time zone; Spring ends June 20th here.![]()
to some, a rhetorical question is one that keeps getting asked over and over with no answer.I know, that was meant to be a rhetorical question....
But The Hopper is an Aussie reference. And Spring isn't until about 6 months.Haha ! I had to look it up actually and turns out there are 3-4 different versions of "spring" (or seasons) !
Limited time offer
