AZBOX - AzBox miniMe American edition version 1.84 firmware | SatelliteGuys.US
AZBOX AzBox miniMe American edition version 1.84 firmware
pwrsurge
919
30
Canada
AzBox Canada and AzBox US are proud to announce the long awaited release of firmware version 1.84 for the AzBox miniMe American Edition.
This new version focuses on improving the receiver's ease of use with the introduction of Easy and Advanced menu modes. By default, Easy menu mode will be selected which hides the more advanced options but for those people who prefer to have all available options to thinker with, the menu mode can be switched by going to Settings -> Personalization and then selecting either "Easy" or "Advanced". The receiver will then prompt for a reboot which must be made anytime Menu mode is switched as most menus are only loaded into memory upon boot.
The following enhancements are included with this new firmware version:
Bug fixes:
  • DiSEqC switch commands, motor movement and other frontend parameters are now sent before doing a blindscan. This allows the user perform a blindscan on a different satellite than the one currently tuned to and corrects the issue SatelliteGuys members Pixl and catamount have experienced.
    Issue reported by Pixl and catamount - Thank you!
  • Fixed mapping for the following remote control keys:
    * <-: Should immediately change to last tuned channel
    * ^: Should show history list instead of Exit key when viewing channel
    * LANG: Should show current audio channel and other audio options instead of green key
    Issue reported by Bob2011 - Thank you!
  • Code optimizations in order to improve blindscan speed when detecting transponders.
    Issue reported by QA
  • Disable inactivity sleep timer by default. On a fresh install, the inactivity sleep timer was previously set to 180 minutes.
  • Updated Youtube player in order to adapt to recent Youtube site changes.
    Issue reported by developers
  • Updated AV libraries to improve multimedia performance and other miscellaneous bug fixes
New features:
  • Added Easy menu mode in order to make receiver more simple to use for the less technically inclined.
  • Separated tuner configuration and channel scan options to their own menus on both Easy and Advanced menu modes in order to make the receiver easier to use. Also, "Channels" on the main menu has been renamed "Installation".
  • A shortcut to scan for channels was added directly from the main menu using the Green button. In order to allow for this, the TV mode and Radio mode options were combined to a single TV-Radio switch option in order to to toggle between TV and Radio mode. This should make feedhunters happy! :)
  • Added dynamic countdown when moving dish which to our knowledge, is a first for any FTA STB. In past firmware versions, the "Moving dish..." message displayed a static amount of seconds estimated for the dish to move. Now, the amount of seconds will countdown to 0 as the dish moves. As always, the message is automatically removed once dish finishes moving.
  • The currently tuned channel is now highlighted in light grey on the channel list.
  • A function was added in order to delete all channels from the currently tuned satellite. This is useful for feedhunters or if you simply wish to do a fresh scan on a satellite with lots of channels. In order to use, first tune to any scanned channel on the desired satellite, press OK to display the channel list, press MENU and then select "Delete current satellite channels". After answering Yes to the confirmation dialog, all channels on the currently tuned satellite except the actual tuned channel will be deleted. Please note that antenna settings are NOT impacted by this function.
  • A new function was added to the green key when viewing a channel in order to display all channels on currently tuned transponder.
  • Satellite and transponder lists were freshly updated for 2014
Available for download now via the Internet update function on network connected receivers or download via our support page on azbox.ca or azbox.us to install using your USB flash drive.
Have fun and happy feedhunting!
Have just loaded this. The first great improvement is the 'delete current satellite channels' then do a fresh blind scan, works just great!
Blind scan seems more robust now. Off to play a bit more a load in my second receiver, but seems a great release!
great work congratulations, and for AzBox Me? will be
Now that we finally were able to release our new miniMe American Edition firmware, we will look into allocating some development resources into making a new AZtrino version for the Me.
I stayed with advanced, so this must work with easy only! No Problem here
Thanks for the delete all channels, which I've been asking for since the first bin.
Catamount
Big problem with this firmware!
Using advanced, Switching channels only works about 50%. When I change channels from channel list or using 0 button for last channel, image freezes on current channel and get scrambled nag. Happening on more than one satellite. Pushing menu/blue/exit/exit/exit doesn't fix the issue.
Going back to 1.7 version
Try doing a shutdown and unplugging the power cord from the receiver for about 1 minute and plugging it back again. This should resolve this issue.
Catamount
Actually, the remote control key remapping are available in both Easy and Advanced menu modes. However, as only the default assignments were changed, these won't change right away if you chose to preserve user settings during the upgrade. There are two ways to fix this:
1. Resetting all user preferences to default by selecting Settings -> Manage settings -> Reset settings to default and then selecting Yes to confirm
Please note that this will NOT impact any antenna settings or scanned channels, only the preferences in the settings menu will be reset to default. The first time you reboot after doing this, you will see the setup wizard again. However, simply pressing the MENU key twice will skip it and you will be brought back to the last viewed channel.
2. If you made extensive personalization changes in the Settings menu and are using Advanced menu mode, you may prefer to fix the remote control key mappings by hand instead. If so, please proceed as follows:
1. Go to: Settings -> Key setup -> Keybinding setup -> Quickzap -> Quick Zap -> setup new key
2. Press the <- key on the remote which is located immediately below the 7 key
1. Select Back to go back to the Quickzap menu
2. Go to: Channel group history -> setup new key
3. Press the ^ key on the remote which is located immediately below the 9 key
1. Select Back -> Back to go back to the Keybinding setup menu
2. Change the Audio key start player preference from on to off.
Reloaded 1.84, receiver came up scrambled on KTV2 upon reboot. Remapped the keys and shut receiver down. Unplugged 5 minutes. Rebooted and still getting scrambled nag. Unplugged power again. Still the same. Can get Cozi and NBC's on 103, but beach channels come up scrambled. Can't get KTV2 or 3, or Russia Today on 97, yet Kurd Tv comes right in.
Everything works fine with 1.7 firmware!
Thoughts? I can rescan satellites, but I think your video drivers have a problem
Thank you for your feedback. After further testing with the example channels you provided, we identified the issue you are referring to. It actually has nothing to do with video drivers but rather with the demux parsing code and only impacts certain transponders. Fortunately, our development team was already able to resolve this issue so we will be releasing firmware version 1.86 later on today once our QA is done testing it.
Issues like this are why it's so important to have North American based development on a product as complex as a satellite receiver.
I'm getting the same issue with some feeds over here in the UK, the picture will freeze then when you channel change you get the 'scrambled' message or 'channel not available' look forward to 1.86
In the meantime as a stopgap measure, going to the picture viewer and exiting out again after you get the 'scrambled' message will bring in the channel.
Version 1.86 passed all QA testing so it is now available for upgrading.
It includes the following enhancements:
Bug fixes:
  • Adjustments to demux parsing code in order to resolve issue receiving certain transponders. Issue reported by catamount and scopus - Thank you!
New features:
  • Values in signal analyzer graph are now displayed as percentages
Nice to know that version 1.86 is working well for you guys. One more thing I noticed is that channel changing to most transponders is a bit faster with this release.
Have fun blindscanning all those Olympic wild feeds! :ok:
1.86 I'm getting the same problems picture freeze when I move from channel to channel on the favors and on the satellites to.But did that on the 1.70 . And need to reboot the receiver to many times.I have channels from 139 west to t12 15 west on all my receivers. All working but minime don't. I think to many setups for the receiver.I do factory settings don't save settings and setup new channel list and old channel list and the same thing.The minime if I setup only few satellites like ku band and few c band are not to bed.
GEOSATpro 1200
Transponder question
