1/23/2014 10:02pm - Uplink Activity Report - 102 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/23/2014 10:02pm - 102 changes
Uplink Comparison Range: 01/22/2014 07:01P - 01/23/2014 10:01P
Channel Additions:
9055(32) - WAWSD [MPEG4 SD] added to Echostar16 61.5W TP 25 Spotbeam 10 (Mkt:Jacksonville, FL-Jacksonville, FL-MN,) (A) (H)
9055(32) - WAWSD [MPEG4 SD] added to Quetzsat1 77W TP 05 ConUS beam (Mkt:Jacksonville, FL-Jacksonville, FL-MN,) (A) (H)
Channel Removals:
5155 - WAWSD (A) (H) [MPEG4 HD] removed from Echostar16 61.5W TP 25 Spotbeam 10 (Mkt:Jacksonville, FL-Jacksonville, FL-MN,)
5155 - WAWSD (A) (H) [MPEG4 HD] removed from Quetzsat1 77W TP 05 ConUS beam (Mkt:Jacksonville, FL-Jacksonville, FL-MN,)
6852 - UP9 (NA) [MPEG4 HD] removed from Echostar16 61.5W TP 07 Conus beam (Virtual Channel)
6852 - UP9 (NA) [MPEG4 HD] removed from Echostar16 61.5W TP 15 Conus beam (Virtual Channel)
Channel Moves:
8569 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Dothan, AL) (A) (H)
6694 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Lafayette, IN) (A) (H)
6764 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Utica, NY) (A) (H)
6514 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Zanesville, OH) (A) (H)
8175 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Abilene, TX) (A) (H)
8258 - KAKW [MPEG2 SD] moved from EchoStar14 119W TP 05 Spotbeam B10 to EchoStar14 119W TP 04 Spotbeam B11 (Mkt:Austin, TX-Killeen, TX-UNIVISION,) (A) (H)
8448 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Beaumont, TX) (A) (H)
7526 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Sherman, TX) (A) (H)
7866 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Mkt:Wichita Falls, TX) (A) (H)
105 - USA [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (USA Network) (A)
107 - CMDY [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Comedy Central) (A)
110 - FOOD [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Food Network ch 9462) (A)
111 - DIY [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Do It Yourself Network) (A)
112 - HGTV [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Home & Garden TV) (A)
115 - ESQNT [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (A) (H)
117 - TVGN [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (TV Guide Network) (A)
118 - A&E [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Arts & Entertainment) (A)
120 - HIST [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (The History Channel) (A)
135 - BBCA [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (BBC America) (A)
136 - FX [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (FX) (A)
139 - TBS [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Turner Broadcasting Service) (A)
140 - ESPN [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Entertainment & Sports Program Network) (A)
141 - ESPNU [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (ESPN U) (A)
142 - ESNWS [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (ESPNews) (A)
144 - ESPN2 [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (ESPN 2) (A)
150 - FOXS1 [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Fox Sports 1) (A)
154 - NFL [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (NFL Network) (A)
160 - MTV [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Music Television) (A)
161 - MTV2 [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Music Television 2) (A)
163 - VH1CL [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (VH1 Classic) (A)
169 - NKJR [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Nick Junior) (A)
170 - NICK [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Nickelodeon/Nick at Nite) (A)
174 - DISXD [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Disney XD) (A)
176 - TOON [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Cartoon Network) (A)
188 - UP [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Uplifting Entertainment) (A)
189 - OWN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Oprah Winfrey Network) (A)
191 - ESQNT [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (A)
195 - MIL [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Military Channel) (A)
200 - CNN [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Cable News Network) (A)
205 - FXNWS [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Fox News Channel) (A)
214 - WEATH [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (The Weather Channel) (A)
241 - SPIKE [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Spike) (A)
259 - INSP [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Inspiration Network) (A)
270 - UNVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Univisión (Este)) (A)
271 - UNIME [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (A) (H)
273 - GLVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Galavisión (Este)) (A)
301 - HBO2E [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Home Box Office 2 (East)) (A)
340 - ENCOR [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Encore (East)) (A)
827 - UNVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Univisión (Este)) (A)
830 - UNIME [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (A) (H)
833 - GLVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Galavisión (Este)) (A)
915 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (PBS National Feed) (A) (H)
4391 - TVGN [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (TV Guide Network) (A) (H)
4502 - A&E [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Arts & Entertainment) (A) (H)
4505 - SPIKE [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Spike) (A) (H)
4511 - USA [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (USA Network) (A) (H)
4525 - TOON [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Cartoon Network) (A) (H)
4529 - CNN [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Cable News Network) (A) (H)
4533 - TBS [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Turner Broadcasting Service) (A) (H)
4543 - FX [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (FX) (A) (H)
4547 - FXNWS [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Fox News Channel) (A) (H)
4553 - FOXS1 [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Fox Sports 1) (A) (H)
4567 - HGTV [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Home & Garden TV) (A) (H)
4574 - OWN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Oprah Winfrey Network) (A) (H)
4584 - ESQNT [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (A) (H)
4598 - BBCA [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (BBC America) (A) (H)
4608 - DIY [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Do It Yourself Network) (A) (H)
4612 - FOOD [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Food Network ch 9462) (A) (H)
4614 - HIST [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (The History Channel) (A) (H)
4620 - MIL [MPEG4 SD] moved from Echostar16 61.5W TP 06 Conus beam to Echostar16 61.5W TP 15 Conus beam (Military Channel) (A) (H)
4640 - DISXD [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Disney XD) (A) (H)
4648 - NICK [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Nickelodeon/Nick at Nite) (A) (H)
4652 - NKJR [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Nick Junior) (A) (H)
4670 - CMDY [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Comedy Central) (A) (H)
4680 - MTV [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (Music Television) (A) (H)
4682 - MTV2 [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Music Television 2) (A) (H)
4687 - VH1CL [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (VH1 Classic) (A) (H)
4727 - WEATH [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (The Weather Channel) (A) (H)
4739 - NFL [MPEG4 SD] moved from Echostar16 61.5W TP 16 Conus beam to Echostar16 61.5W TP 15 Conus beam (NFL Network) (A) (H)
4780 - ESPN [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Entertainment & Sports Program Network) (A) (H)
4782 - ESPN2 [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (ESPN 2) (A) (H)
4786 - ESNWS [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (ESPNews) (A) (H)
4788 - ESPNU [MPEG4 SD] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (ESPN U) (A) (H)
4798 - UNVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Univisión (Este)) (A) (H)
4802 - UNIME [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (A) (H)
4806 - GLVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Galavisión (Este)) (A) (H)
5408 - FOXSD [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to Ciel-2 129W TP 27 ConUS beam (Fox Sports San Diego) (A) (H)
5408 - FOXSD [MPEG4 HD] moved from Nimiq5 72.7W TP 10 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (Fox Sports San Diego) (A) (H)
5918 - UP [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Uplifting Entertainment) (NA)
6166 - UNVSN [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (Univisión (Este)) (NA)
6167 - UNIME [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (NA)
6170 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (PBS National Feed) (NA)
9595 - PBS [MPEG4 SD] moved from Nimiq5 72.7W TP 05 ConUS beam to Echostar16 61.5W TP 07 Conus beam (PBS National Feed) (A) (H)
19030 - CNNAP [DATA] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (A)
19075 - TWCAP [DATA] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (A)
19239 - SPRTS [DATA] moved from Nimiq5 72.7W TP 23 ConUS beam to Echostar16 61.5W TP 07 Conus beam (A) (H)
Channels in the system: 8998
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
A lot of these were from overnight last night...
I came home awhile ago and noticed the dish that does the uplink report was covered and coated in snow. It was so hard that I had a hard time chipping it off the LNB and DISH. I think in the process of clearing off the dish I may have moved it just slightly. I will have to check it with the meter in the morning.
My appologies for the delayed report!
Thanks Scott. One wonders what Dish is up to with all these SD channel moves. IMHO they're all a waste of bandwidth for those of us with HD. Although, speaking of snow, I did have an event last week that made my SS marginal on HD transponders, and my VIP receivers switched over to the equivalent SD channel just fine. Also surprised at use of only 2 transponders for so many SD channels. :eek:
Sorry, I am not versed enough to know this, but does this mean for Eastern Arc it would be possible for all those channels to be removed as SD channels leaving only the HD version (assuming these channels have or will have HD versions). All receivers on Eastern Arc would be fine downconverting to SD if the customer only had an SD set? I know that in my market, only HD locals exist.
And why the move from TP15 to TP16 for several channels on 61.5 then several others from TP16 to TP15? Seems like trying to group in a certain way.
maybe allow the hopper to record more channels at the same time much like they do with locals?
For my father in laws 90th birthday, my wife and her siblings upgraded his main tv to an LG 42 inch hd tv. He and his wife had upgraded their kitchen tv to hd already.
BTW, he is still working as a self employed plumber on the island of Nantucket.
I prefer HD, but if a program that was originally shot in SD 4x3 is being broadcast in HD and the image is artificially stretched to 16x9 wide with no way to fix it on my end, I would rather watch the proper aspect ratio in SD than an HD variety distorted.
D
1/28/2014 5:02pm - Uplink Activity Report - 2 changes
D
1/29/2014 7:32am - Uplink Activity Report - 2 changes
