wanting to get some radio music in my shop. | SatelliteGuys.US
chaskuchar
807
14
saint charles, missouri
thought 91w would have channels per thelist but nothing comes up there. I remember lyngsat.com but it didn't have anything there either. and I can't remember the other places I could look at the satellite channels. any clue where I can get some radio channels with old country music. the new country music doesn't seem like country. guess I am getting too old... charlie
No internet available? I don't know what's out there on FTA but if streaming audio from the internet is an option you can get just about any music you want from free, legal sources.
Music Choice has one country station in the clear on 97W (12053 V 22000) labeled as "Music Test Channel." Seems ok and not too contemporary, but I don't recognize a lot playing there right now. You'd have to listen in to know for sure :)
Edit: ok, it sounds a bit more contemporary now :( Anyway, see if it works for ya. It doesn't for me hehehe
there are no simple projects anymore!!! first I tried to scan 103w. kept getting the channels on 101w. went to 97w. dish was working there ok. I have the microhd, a 1.2 from satav and a dg380 motor from sadoun. went to 72w. working ok. tried to go to 125w. hmmmm. dish didn't move... now this is probably 3 hours into getting printout of channels and resetting microhd to factory reset and booting it up and then tried resetting dish motor by pressing both buttons and dish moved east and then moved back to 97w which is south. would not move past 101w going west. went out to the dish, and it's cold here in Nebraska, and the dish moved to 125w ok. after moving it I was able to go to 103w and scan for channels. 12145v20000 was there and I tried to input the pids from the audio list but nothing has taken so far. I did get the manual out for the microhd and put the pids in audio and the bottom entry and left the video at 8190 but nothing registered. oh well, got the dish moving again. charlie
Don't know how to help you with the MicroHD, but 103W is where you want to be. There is some good ole country music there. Pids 7512 thru 7515, especially 7513 should get your toes a tapping. On my sonicview I have the video pid and pcr both set at 8192.
Her you go Charlie,
C/p from Vendig at Rick's. I know it's posted here, but couldn't find it!
If using the micro hd this is how you would have install the Muzak channels.
It is easier if you first add the freq, SR settings and download any channels from that mux first. Then when you want to edit your channel list part of it is already in there for you.
place a usb stick in the receiver.
hit Menu then go to TOOLS, click on SAVE TO USB
under "SAVE MODE" arrow over to, "userdb"
The "SAVE FILE" will show up with the same file, "userdb",
now click on "START" to save this file to the usb stick.
When done exit out and remove the usb stick and put it in your PC.
Using Ali Editor,
Click on "FILE" then "OPEN" and locate your "userdb" file on your usb stick.
Once your list shows up on the left side panel, click on "ALL SERVICES, then "SATELLITE INFORMATION", Now click on "103W K AMC 1".
Then click on the transponder freq for these channels.
My list had it as 12144_V_20000
The main box will now show up in the center for the channels to edit.
Right click in that box and use "INSERT CHANNEL".
I used my list as TV instead of Radio so here is how my setup appeared in that box.
Channel Name > use for the list given. example (Moe's SW Grill)
Service id = 0
video Pid = 8190
PCR = Audio pid from the list given above example (7586)
Audio Type 1 = Mpeg 2
Audio Type 2 = Mpeg 2
Audio Type 3 = Mpeg 2
H264 Flag = Mpeg 2
Group = blank (left it empty)
Scramble = no
Factory = no
Audio Mode = Stereo
Audio Pid 1 = pid from the list given above example (7586)
Audio Pid 2 = pid from the list given above example (7586)
Audio Pid 3 = pid from the list given above example (7586)
Once done press "OK"
Now the channel will populate on your screen so check it over to make sure the audio pids are in there properly.
Save the file and then upload it to your Micro HD receiver.
Insert the usb stick in the Micro HD
click on Menu , Tools, then "UPDATE by USB"
in Upgrade Mode arrow over to "USERDB"
The File Name will also be the Same.
Now press Start.
Allow the receiver to do it's thing do not remove the usb stick until the receiver reboots
Since I use these under the TV and not Radio this is how I inserted the Muzak channels in the Micro HD receiver.
Sorry, forgot the pids!
MUZAK CHANNELS
12145/V/20000//3/4//DVB-S/QPSK
audio
pids
7496 50's and 60's Hits
7497 70's Hits
7498 Songbook
7499 80's Hits
7500 Country Holiday empty now
7501 Backpages
7502 Cashmere
7503 Unforgettable
7504 City Lights
7505 The Beach
7506 Swing Kings
7507 Lucille
7508 7890
7509 Ensemble
7510 Summer Fun was (Traditional Holiday)
7511 Rock Show
7512 Roadhouse
7513 Country Gold
7514 Nashville USA
7515 Country Music
7516 Belissimo
7517 The Light
7518 Plaza
7519 Impressions
7520 Summer Fun (was Holiday Instrumentals)
7521 Easy Instruments
7522 Environmental
7523 Frequency
7524 Expressions
7525 Ambrosia
7526 FM-1
7527 Hit Line
7528 Hot FM
7529 Strobe was (Holiday Remix)
7530 Little Italy
7531 Jazz Traditions
7533 Jukebox Gold
7534 Ultra Hip Holiday empty now
7535 La Musica was (Latino Navidad)
7536 Intermezzo
7537 Love Songs
7538 Feedback
7539 Metro
7540 Latino Navidad-2 empty now
7541 Moodscapes
7542 Aura
7543 Shine
7544 The Party Playlist
7545 NU Jazz
7546 Piano and Guitar
7547 The Café
7548 Mo' Soul
7549 Reflections
7550 empty was (Kingston)
7551 Toned empty now
7552 Tropical Breezes
7553 The Boulevard
7554 Concrete Beats
7555 Viva Mariachi
7556 Shoprite Commercials
7557 Nu Lounge
7558 La Musica
7559 Hobby Lobby empty now
7560 Don Pablos
7561 Price Shopper Commercials
7562 RL Music Program
7563 Quebicos
7564 Stater Brothers Radio
7565 Popeyes Radio
7566 Holiday Pop empty now
7567 Commercials
7568 The Circuit
7569 Perimeter
7570 The New Wave
7571 Varsity
7572 Stylus
7573 empty (Classic Holiday)
7574 Curves 4 Women
7575 Fameous Footware
7576 Mens Wearhouse
7577 Pet Smart
7578 Radio DWS
7579 FM DOS
7580 Sprints Main
7581 Sports Authority
7582 Costs Plus
7583 Soulful Holiday
7584 Uptown
7585 Exxon Mobile empty now
7586 Moes SW Grill
7587 McDonalds
7588 Office Max
7589 Chase
7590 Sprint
7591 Chase Main
7592 Promo 3 empty now
7593 Promo 4 empty now
7594 Ultra
7595 unknown now EMPTY
Audio Mode = Stereo
Reactions: oldsmobile
Glad to hear you got the dish moving again.
On the Pansat 3500, The PCR has to be the same as the audio PID programmed.
thanks catamount. i am listening to country gold. now need to add more channels and rename the userdb to a date/name so i don't lose it. there was a minor difference in your instructions. some steps were not needed in my fill-in-box on the ali editor. i did the tv and as soon as the 103w came up, the channel was there. thanks so much. charlie
No problem here on Firefox! I went there before I responded to Charlie. Nothing to do with what Charlie needed. It was 99 C-band channels Fatair was looking for.
Catamount
http://www.satelliteguys.us/threads/325827-Hidden-channels-103W?p=3323759#post3323759 works for me.
here it is without being a link so copy and paste: hxxp://www.satelliteguys.us/threads/325827-Hidden-channels-103W?p=3323759#post3323759 Don't copy hxxp:// It's in the WUT so ?????????? as you are pub members??????
post3323759 has the attached file with the pids for the audio channels in question. No longer necessary as you've posted them here.
I didn't hear any classical. Lost that one I used for music on the beach feeds a while ago also. Haven't heard any others either. :(
EMP Centauri 4x1 Diseqc 2.0 Switch and MicroHD
MicroHD Question
