Shaw PVR630 Static IP? | SatelliteGuys.US
Probably the same unique setup I have (connect only to VPN).
Just go to VOD, Network. The select DHCP and set to Disabled. Then go to the TCP/IP properties option and populate your settings.
shaw direct two dish lnb? switch ?
? can i use switch shaw 2 dishes
