Set up help for 2 anntenas for Shaw Direct in Mexico | SatelliteGuys.US
panchocuerdas
12
2
Mexico City
The 2 main satellites for Shaw (Anik F1R and Anik F2) work as far south as Central America.
I have two separate 6 feet antennas to serve my 630 Motorola equipment
I have two coaxial cables hooked to the equipment, but I have problems with the Micro switches
They have to Sat ports one for 13v and one for 18 V which antena goes in 13 and wich one goes in 18? I have two switches hooked to 2 switches and frome each switch a cable to the 630 Motorola equipment
Questions
1.- need to be an order on what hooks to Sat 18 V and what to hook in Sat 13V ?
2.- do I need 2 switches? one per cable to the RX? (since this equipment has a PVR you need two signals) each Zinwell switch has 2 Sat terminals but up to 4 RX exits do I need two switches or I can hook the two coaxial cables to the IRD to the same switch.
Thanks in advance for the help!
Are your LNBs single or dual output?
You will need dual output LNBs on each dish, and a 4 input by however many x output switch based on how many ports you need for the number of receivers you want to connect.
13 and 18 v is used to select polarity on each satellite, then the switch selects the dish by tone.
Questions
Right, you need two input lines for the 630,
if you´re using dual output lnbs´s you´d have 4 lines, 2 for each sat.
Shaw works with 22khz tones so you need a 22khz switch.
You could use 2 switches to combine F1 and F2, and then have 2 incoming lines to the receiver. F2(111w) goes on the 22khz side,
http://www.satelliteav.com/p/shop/?ws_pid=1371&ws_cat=429
Or I think you may use a multi 22khz, hopefully someone has had experience with this switch and may provide feedback.
http://www.satelliteav.com/p/shop/?ws_pid=654&ws_cat=429
If your lnbs have a single output, you need to split both sat lines, since you will need 2 lines (with both F1 and F2) for the 630.
If you don´t want to first split the signal and then use the 22khz switch, you could get dual output lnbs and just use the 22khz switch as mentioned above.
Shaw set-up South of the border
Nimiq 91 is alive in NC!
