With the proper software (TSReader I believe?), you should be able to record any or all of a single transponder.
I wrote most of the FAQ called Switches Simplified, and the minute someone says "splitter", I see red!
Which dual lnbfs and what switch configuration are you using?
My PC didn't come with the necessary 4-pin molex power connector (as these are no longer used in Serial ATA based HDDs). I had an external adapter that could supply it with power, but I would have to keep the tower open and I am not sure if it would be the correct voltage.
Thirdly, I have no clue why some channels just show a black screen when I tune to them. They used to work before (like Al Jazeera English). Would a low signal quality do that? My assumption was that it would indicate that there is no signal. Could it be the receiver? Anyone here with a dish pointed to Galaxy 19 who can confirm these for me?
Limited time offer
