6/19/2013 6:17pm - Uplink Activity Report - 120 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/19/2013 6:17pm - 120 changes
Uplink Comparison Range: 06/19/2013 02:31P - 06/19/2013 06:16P
Channel Additions:
5190(7) - KATV [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Little Rock, AR-ABC) (NA)
5191(11) - KTHV [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Little Rock, AR-CBS) (NA)
5192(4) - KARK [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Little Rock, AR-NBC) (NA)
5193(16) - KLRT [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Little Rock, AR-FOX) (NA)
5194(2) - KETS [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Little Rock, AR-PBS) (NA)
5195(42) - KARZ [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Little Rock, AR-MNT) (NA)
5196(38) - KASN [MPEG4 HD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Pine Bluff, AR-CW) (NA)
9357(25) - KVTN [MPEG4 SD] added to Unknown TID#1331 (Mkt:Little Rock, AR-Pine Bluff, AR-REL) (NA)
9358(49) - KMYA [MPEG4 SD] added to Unknown TID#1331 (Mkt:Little Rock, AR) (NA)
5150(25) - WJXX [MPEG4 HD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Orange Park, FL-ABC) (NA)
5151(47) - WTEV [MPEG4 HD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Jacksonville, FL-CBS) (NA)
5152(12) - WTLV [MPEG4 HD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Jacksonville, FL-NBC) (NA)
5153(30) - WAWS [MPEG4 HD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Jacksonville, FL-FOX) (NA)
5154(4) - WJXT [MPEG4 HD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Jacksonville, FL-IND) (NA)
5155(32) - WAWSD [MPEG4 HD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Jacksonville, FL-MY) (NA)
5156(17) - WCWJ [MPEG4 HD] added to Unknown TID#1131 (Mkt:Jacksonville, FL-Jacksonville, FL-CW) (NA)
5157(7) - WJCT [MPEG4 HD] added to Unknown TID#1131 (Mkt:Jacksonville, FL-Jacksonville, FL-PBS) (NA)
9058(8) - WXGA [MPEG4 SD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Waycross, GA-PBS) (NA)
9059(59) - WJEB [MPEG4 SD] added to Unknown TID#1125 (Mkt:Jacksonville, FL-Jacksonville, FL-TRIN) (NA)
5290(9) - WTVM [MPEG4 HD] added to Echostar16 61.5W TP 03 Conus beam (Mkt:Columbus, GA-Columbus, GA-ABC) (NA)
5291(3) - WRBL [MPEG4 HD] added to Echostar16 61.5W TP 03 Conus beam (Mkt:Columbus, GA-Columbus, GA-CBS) (NA)
5292(38) - WLTZ [MPEG4 HD] added to Echostar16 61.5W TP 03 Conus beam (Mkt:Columbus, GA-Columbus, GA-NBC) (NA)
5293(54) - WXTX [MPEG4 HD] added to Echostar16 61.5W TP 03 Conus beam (Mkt:Columbus, GA-Columbus, GA-FOX) (NA)
5294(28) - WJSP [MPEG4 HD] added to Echostar16 61.5W TP 03 Conus beam (Mkt:Columbus, GA-Columbus, GA-PBS) (NA)
5295(49) - WLGA [MPEG4 SD] added to Echostar16 61.5W TP 03 Conus beam (Mkt:Columbus, GA-Opelika, AL-CW) (NA)
5190(8) - WQAD [MPEG4 HD] added to Unknown TID#1075 (Mkt:Davenport, IA-Moline, IL-ABC) (NA)
5191(4) - WHBF [MPEG4 HD] added to Unknown TID#1075 (Mkt:Davenport, IA-Rock Island, IL-CBS) (NA)
5192(6) - KWQC [MPEG4 HD] added to Unknown TID#1075 (Mkt:Davenport, IA-Davenport, IA-NBC) (NA)
5193(18) - KLJB [MPEG4 HD] added to Unknown TID#1075 (Mkt:Davenport, IA-Davenport, IA-FOX) (NA)
5194(36) - KQIN [MPEG4 HD] added to Unknown TID#1075 (Mkt:Davenport, IA-Davenport, IA-PBS) (NA)
5195(24) - WQPT [MPEG4 HD] added to Unknown TID#1075 (Mkt:Davenport, IA-Moline, IL-PBS) (NA)
7604(26) - KGCW [MPEG4 SD] added to Unknown TID#1075 (Mkt:Davenport, IA-Burlington, IA-CW) (NA)
5270(25) - WEHT [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Evansville, IN-ABC) (NA)
5271(44) - WEVV [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Evansville, IN-CBS) (NA)
5272(14) - WFIE [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Evansville, IN-NBC) (NA)
5273(7) - WTVW [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Evansville, IN-FOX) (NA)
5274(12) - WNIN [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Evansville, IN-PBS) (NA)
5275(31) - WKOH [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Owensboro, KY-PBS) (NA)
5276(45) - WEVVD [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Evansville, IN-Evansville, IN-N/A) (NA)
5150(36) - WTVQ [MPEG4 HD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Lexington, KY-ABC) (NA)
5151(27) - WKYT [MPEG4 HD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Lexington, KY-CBS) (NA)
5152(18) - WLEX [MPEG4 HD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Lexington, KY-NBC) (NA)
5153(56) - WDKY [MPEG4 HD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Danville, KY-FOX) (NA)
5155(46) - WKLE [MPEG4 HD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Lexington, KY-PBS) (NA)
9209(28) - WKYT2 [MPEG4 SD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Lexington, KY-CBS) (NA)
9212(65) - WLJC [MPEG4 SD] added to Echostar16 61.5W TP 05 Conus beam (Mkt:Lexington, KY-Beattyville, KY-REL) (NA)
5150(3) - WSIL [MPEG4 HD] added to Unknown TID#1427 (Mkt:Paducah, KY-Harrisburg, IL-ABC) (NA)
5151(12) - KFVS [MPEG4 HD] added to Unknown TID#1427 (Mkt:Paducah, KY-Cape Girardeau, MO-CBS) (NA)
5152(6) - WPSD [MPEG4 HD] added to Unknown TID#1427 (Mkt:Paducah, KY-Paducah, KY-NBC) (NA)
5153(23) - KBSI [MPEG4 HD] added to Unknown TID#1427 (Mkt:Paducah, KY-Cape Girardeau, MO-FOX) (NA)
5154(29) - WKPD [MPEG4 HD] added to Echostar16 61.5W TP 29 beam (Mkt:Paducah, KY-Paducah, KY-PBS) (NA)
5155(8) - WSIU [MPEG4 HD] added to Unknown TID#1427 (Mkt:Paducah, KY-Carbondale, IL-PBS) (NA)
5156(49) - WDKA [MPEG4 HD] added to Unknown TID#1427 (Mkt:Paducah, KY-Paducah, KY-MY) (NA)
9262(27) - WTCT [MPEG4 SD] added to Unknown TID#1427 (Mkt:Paducah, KY-Marion, IL-REL) (NA)
9263(9) - WQWQ [MPEG4 SD] added to Unknown TID#1427 (Mkt:Paducah, KY) (NA)
9265(32) - WPSDD [MPEG4 SD] added to Unknown TID#1427 (Mkt:Paducah, KY-Paducah, KY-N/A) (NA)
5200(33) - KSPR [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO-Springfield, MO-ABC) (NA)
5201(10) - KOLR [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO-Springfield, MO-CBS) (NA)
5202(3) - KYTV [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO-Springfield, MO-NBC) (NA)
5203(5) - KRBK [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO-Osage Beach, MO-N/A) (NA)
5204(27) - KOZL [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO) (NA)
5205(21) - KOZK [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO-Springfield, MO-PBS) (NA)
5206(15) - KCZ [MPEG4 HD] added to Unknown TID#1408 (Mkt:Springfield, MO-Springfield, MO-CW) (NA)
6427(16) - KUNP [MPEG4 HD] added to EchoStar10 110W TP 29 Spotbeam 44 (Mkt:Portland, OR-La Grande, OR-UNI) (NA)
5130(28) - KAMC [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-ABC) (NA)
5131(13) - KLBK [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-CBS) (NA)
5132(11) - KCBD [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-NBC) (NA)
5133(34) - KJTV [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-FOX) (NA)
5134(22) - KLCW [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Wolfforth, TX-CW) (NA)
5135(5) - KTTZ [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX) (NA)
5137(14) - KMYL [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-MY) (NA)
5138(46) - KXTQ [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-N/A) (NA)
7944(16) - KPTB [MPEG4 SD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-REL) (NA)
5170(9) - KTRE [MPEG4 HD] added to Unknown TID#1382 (Mkt:Tyler, TX-Lufkin, TX-ABC) (NA)
5171(7) - KLTV [MPEG4 HD] added to Unknown TID#1382 (Mkt:Tyler, TX-Tyler, TX-ABC) (NA)
5172(19) - KYTX [MPEG4 HD] added to Unknown TID#1382 (Mkt:Tyler, TX-Nacogdoches, TX-CBS) (NA)
5173(56) - KETK [MPEG4 HD] added to Unknown TID#1382 (Mkt:Tyler, TX-Jacksonville, TX-NBC) (NA)
5174(51) - KFXK [MPEG4 HD] added to Unknown TID#1382 (Mkt:Tyler, TX-Longview, TX-FOX) (NA)
5175(59) - KERA [MPEG4 HD] added to Echostar16 61.5W TP 24 Spotbeam 15 (Mkt:Tyler, TX-Dallas, TX-PBS) (NA)
8887(54) - KCEB [MPEG4 SD] added to Unknown TID#1382 (Mkt:Tyler, TX-Longview, TX-CW) (NA)
6655 - WSVF2 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam B16 (NA)
Channel Removals:
654 - DUBAI (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 26 ConUS beam (Dubai TV)
818 - ATN (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 03 ConUS beam (ATN Bangla Bangla (Bangladesh))
5000 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5000 - VLCTY (A) (H) [MPEG4 HD] removed from Nimiq5 72.7W TP 21 ConUS beam
5001 - UNIHD (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam (Universal HD)
5001 - UNIHD (A) (H) [MPEG4 HD] removed from Nimiq5 72.7W TP 21 ConUS beam (Universal HD)
5002 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5003 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5004 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5005 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5005 - VLCTY (A) (H) [MPEG4 HD] removed from Nimiq5 72.7W TP 21 ConUS beam
5006 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5007 - VLCTY (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam
5007 - VLCTY (A) (H) [MPEG4 HD] removed from Nimiq5 72.7W TP 21 ConUS beam
5008 - UNIHD (A) (H) [MPEG4 HD] removed from EchoStar14 119W TP 16 ConUS beam (Universal HD)
5008 - UNIHD (A) (H) [MPEG4 HD] removed from Nimiq5 72.7W TP 21 ConUS beam (Universal HD)
6841 - UP29 (NA) [MPEG4 HD] removed from Echostar16 61.5W TP 23 beam (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Echostar16 61.5W TP 29 beam (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1075 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1125 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1131 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1331 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1382 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1408 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Unknown TID#1427 (Virtual Channel)
6852 - UP9 (NA) [MPEG4 HD] removed from Echostar16 61.5W TP 03 Conus beam (Virtual Channel)
6852 - UP9 (NA) [MPEG4 HD] removed from Echostar16 61.5W TP 05 Conus beam (Virtual Channel)
Channel Moves:
713 - WLLOW [MPEG2 SD] moved from Anik F3 118.7W TP 31 ConUS beam to Anik F3 118.7W TP 03 ConUS beam (A) (H)
Channel Package Flag Changes:
5180(7) - WVII [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 01 changed to Available (H) (Mkt:Presque Isle, ME-Bangor, ME-ABC)
5181(8) - WAGM [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 01 changed to Available (H) (Mkt:Presque Isle, ME-Presque Isle, ME-CBS)
5182(2) - WLBZ [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 01 changed to Available (H) (Mkt:Presque Isle, ME-Bangor, ME-NBC)
5184(10) - WMEM [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 01 changed to Available (H) (Mkt:Presque Isle, ME-Presque Isle, ME-PBS)
6733(16) - WAGMD [MPEG4 SD] - Echostar16 61.5W TP 32 Spotbeam 01 changed to Available (H) (Mkt:Presque Isle, ME-Presque Isle, ME-FOX)
9457(194) - AMERI [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to free preview (A)
9457(194) - AMERI [MPEG4 HD] - Nimiq5 72.7W TP 30 ConUS beam changed to free preview (A)
9489(184) - APL [MPEG4 HD] - Ciel-2 129W TP 19 ConUS beam changed to free preview (A) (Animal Planet)
9489(184) - APL [MPEG4 HD] - Nimiq5 72.7W TP 11 ConUS beam changed to free preview (A) (Animal Planet)
Channel Renames:
384 - FOXMO (Fox Movie Channel) - EchoStar11 110W TP 15 ConUS beam renamed to FXM (A)
384 - FOXMO (Fox Movie Channel) - Echostar16 61.5W TP 16 Conus beam renamed to FXM (A)
Channels in the system: 8841
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated
Looks like a bunch of the markets on 77w (conus) are now in the 61.5W (unavailable) spot table. Could be the beginning of the end of Conus locals.
Since I receive the Louisville locals...........what does that mean?
In case you are not familiar with the term, ConUS means that the signal is available anywhere in the Continental/Contiguous US (Lower 48). Spot Beam means the signal is available only in a "narrow" area or a particular "spot" with only a couple hundred mile radius. This allows the same frequencies to be reused throughout the country to allow for more local channels.
So right now if you were to take your Louisville Dish set-up to Ogden Utah, it would work the same now as it does in Louisville. If Louisville locals go to a spot beam (on 61.5) then you would not be able to watch your Louisville locals in Ogden. :)
All right Lubbock, Texas locals FINALLY on Dish.
That's the good news, the bad news is last month when Dish installed my Hopper, they disconnected my 61.5 Dish.
Dish is sending a tech out Tuesday to reconnect my D500 pointed at 61.5.
EDIT - Looks like they are uplinked and not available yet.
These locals say "5130(28) - KAMC [MPEG4 HD] added to Echostar16 61.5W TP 23 beam (Mkt:Lubbock, TX-Lubbock, TX-ABC) (NA)", does the N/A mean they are not turned on yet?
Advanced Tech CSR won't give me 61.5 until the Lubbock locals become available. They might test them on 61.5 and move them to another satellite when they are made available. Most folks in Lubbock do not have 61.5. We are on the western arc.
Their systems will not allow them to do that until the channels are made available. The system (and CSR's) dont know whats uplinked or when they will be available.
D
7/1/2013 5:32pm - Uplink Activity Report - 2 changes
D
7/2/2013 6:32am - Uplink Activity Report - 4 changes
