New Update Software Version S311 Hopper with Sling Is Here | SatelliteGuys.US
Yup. S246 on vanilla Hopper too. So far really liking the update.
Sent from my iPhone 4S using Forum Runner
OT question. When in the DVR/Playlist screen, you of course have colored tabs up at the top you can use for a quick movement on the remote (yellow, gree, etc...) One of them is usually gray in color, is there a remote button assigned to it?
Using this image for example, the gray button is to change from one Hoppers list to the next.
Not that I am aware of.
Regarding the gray buttons:
You can use one of the others that in a no-operation and then move right/left to the gray.
Do NOT press REMOVE (blue?), unless you mean it.
-Ken
You lost me on that one Ken.
It might be too soon to mention, but my "Favorites" was where I left it last night, but it does that at times.
Dan
I have always just hit DVR, arrow up to red, over to Gray and Select. Gives me the choice of either of my 2 Hoppers or the ehd attached to the paired Hopper.
There are menu like the DVR Schedule where you cannot go up to the button bar because it just keeps scrolling.
You really must use a button to get there. Directly from DVR works because you are at the top.
-Ken
-Ken
If you accidentally hit the blue button and delete a program, you can go into the deleted programs tile and send it back....
Yes although a delete button would be convenient on the EHD, as there is no Deleted Folder on the EHD it is probably best that there is no "Blue" button on its menu. I just wish it would keep its place to got on to the next when finishing or deleting an EHD show.
-Ken
ViP722 & Home Distribution (TV2)
