Live NBC Networks on DISHANYWHERE.COM | Page 2 | SatelliteGuys.US
MSNBC is starting to beat CNN in the ratings, especially in key advertising demos. So, if your logic holds true, MSNBC should replace CNN in AT120 and AT120+ soon, right? :)
Except that CNN got their placement way back when they were #1. Fox started in a higher tier, but eventually got their spot after kicking CNN to the curb in ratings.
If/when MSNBC gets the ratings & marketpower to command a lower tier, then it too will move into a better package.
Just thought I would mention that I found where you can see the networks that they stream LIVE.
When on the DISH ANYWHERE website - upper left hand side, hover over SHOWS and then select NETWORKS.
When the network squares are displayed, the ones that support live viewing will have a blue WATCH LIVE icon on the bottom right hand side.
Unfortunately, us Hawks fans that have AT200 aren't able to watch game 7 tonight because NBC Sports Network is not available. :-(
NCIS LA - Late complaint
Episode numbers out of order
