Hard Drive Question | SatelliteGuys.US
Hard Drive Question
There is no way to tell the individual Mb amount remaining on any of our receivers. It will only let you know how full the hard drive is. I can't say if the feature will be added in the future, but I can pass it forward for you as a request.
If you have an external drive go to the menu and select external hard drive. Then select external drive in the transfer from box. Then select hopper set top box in the transfer to side . At the top you will see the # of GB freespace. Do the reverse to see freespace on the EHD.
It used to show the amount available on S238. This went away with S244. Now you have to pretend to do a transfer from the EHD to Hopper to see the Hopper free space on the user partition.
No Auto-Hop, Prime Time Recordings Disappear By Next Morning
How Long Has My 722k Had THIS DVR Feature?
