Will a new dish work on | SatelliteGuys.US
The D10 recvr powers the LNB on the dish set up, while the SWM has a Power Inserter to power the LNB, now you Don't need a SWM unless it's something you want. It basically makes life easier with only needing 1 line to each dvr recvr.
So will a swm dish work with a NON DVR ? just HD receiver like a H25?
Sure, as long as it's one of the compatible models. Virtually all H and HR models are swm compatible.
With the exception of the h(r)10. A better comparison is all ka compatible boxes are swm capable. However the h20 is not mrv compatible and the HR20-100 requires a special setup. For standard boxes only the d12 is swm capable.
Sent from my SPH-L710 using Tapatalk 2
That's why I said virtually. The HR10 and HR20-100 aren't common anymore.
DIRECTV Tops DISH and AT&T Uverse in ASCI
Another Mirror Question involving 3D
