rexlan SatelliteGuys Pro Original poster Mar 15, 2009 421 44 May 15, 2013 #1 If you buy the equipment outright does Dish still charge for it's use and if so how much? Not about which programing ... just about the equipment. Is it better to just get from Dish? Thanks
Scherrman SatelliteGuys Master Supporting Founder Mar 14, 2008 15,555 9,951 Eastern Iowa May 15, 2013 #2 rexlan said: If you buy the equipment outright does Dish still charge for it's use and if so how much? Not about which programing ... just about the equipment. Is it better to just get from Dish? Thanks Click to expand... The monthly fees for receivers are the same if you own or lease the equipment. The only benefit to own equipment is to avoid a commitment.
navychop - Pub Member / Supporter Lifetime Supporter Jul 20, 2005 62,277 30,574 Northern VA May 15, 2013 #3 If you own a Joey you can call Dish and activate and deactivate it, so you only pay for actual days of use. Good for Joeys not regularly used, as in for guests. Sent from my iPhone using SatelliteGuys
rexlan SatelliteGuys Pro Original poster Mar 15, 2009 421 44 May 15, 2013 #4 Thanks ... sounds like best to just get from Dish then.
