Ouch!! Cracked the screen on my S3. Looks like I can remove it with a heat gun. But, risk of torching the underlying digitizer. Hmm $20 for screen and take a change or $100 + time and package costs for the pros to do it.
is all 16 G (or whatever) available for apps and files or is it still split like an internal SDCard?If I knew what that meant I might be able to answer the question.![]()
Yes, the on/off button is the remote sensor.
I think(!) that answers it. I'll have a look at one at a sprint store soon. I have another year before I can swap againThe smallest one is 32gb. The reviews I have read show all of it available minus what is used internally. I'm not sure if that answers your question.
If you can get it done for around a $100, that is good. I couldn't find any place around Tulsa to do my S3 for less than $300. I just put a zagg screen protector on it and have dealt with it. Mine has one spot where I dropped a stapler on it and the rest of the screen split into about 5 big pieces. I only noticed it when the screen is off, when its lit up you can't tell it is cracked. I'll probably get an S4 or Note 2 later this summer
That said, even with the new one coming, I can recommend the note 2 enough. If you can get it for a deal, it should serve you just as well.
A old guy friend got a note 2 a couple months ago. So, he asks me to hot spot him at coffee.
I tell him he just needs to turn on data and use his plan.
He says his son pays the company bill and data for dad is too expensive
The son only clears a million or so every year and the old man gave him the business!!!
Sent from my S3 using SatelliteGuys
Exchange Email with Voice Mail
Can anyone listen to their Voice Mail in Outlook for Exchange?? I can see the voice mail when it comes in as a Wav file but when you click on it to listen to the file it says Unable to listen to this type of file??
RadioShack bundles the HTC One with a $50 Play Store credit
http://www.phonearena.com/news/RadioShack-bundles-the-HTC-One-with-a-50-Play-Store-credit_id42209
Limited time offer
