GEOSATpro - IR file for Crestron or Pronto Classic HEX | SatelliteGuys.US
GEOSATpro IR file for Crestron or Pronto Classic HEX
trinidex
892
Hi guys,
I'm looking for an IR file to use with a Crestron system.
It can be either native Crestron or a Pronto HEX format.
TIA
Do not have the codes for the microHD but I used a Coolsat 8000HD in the URC editor for my MX-850 remote and it worked for most of the keys. I had to learn just a few from the supplied remote. So I would check Remote Central for Coolsat 8000HD in Pronto format. My editor will not export hex codes.
GEOSATpro Decode video without needing PID.
GEOSATpro Recording Quality
