Kijiji, eBay, and Craigslist dishes for you to take a look at | Page 2 | SatelliteGuys.US
$150 - 10' mesh BUD - Chandler, AZ
http://phoenix.craigslist.org/evl/ele/3622186699.html
Boom into your truck two hour minimum is usually $300 or less. They are bonded for any lift incident. You will likely be driving away from the property with the dish in your truck within 30-45 minutes. Well worth it in my opinion!
Might be nice to have the crane set it at your home, too. :)
But more to the point, it depends on the dish and how hard up you are.
Better be a damned fine dish from a very short list.
Better have an H-H motor under it.
Extra points if it's got an ortho feed horn. ;)
"new" 4 foot prime focus? I thought these were only popular/used in Europe.
Cheers, K
They are new in the box and appear to be quite a few years old. They weigh a ton and are built like battleships.
After a bit of haggling I picked up a new in box 80cm offset dish from this seller. That was the only pole mount offset they had.
The prime focus they have for sale might be interesting to play with, you'd have to move it manually or leave it parked, but not at their asking price.
Re: more Craigslist dishes for your perusal
Sounds like too much work.
I'd love to see a picture or two.
The boxes for the prime focus dishes for sale were marked Pansat.
Ive has a 3ft ring mount from Pansat for 10yrs and still using it ..
Doesn't surprise me, they're well built, though a ring mount on the ground is not practical for my situation.
No pics?
Sorry for hijacking.
Testing the Titanium C140 and C240 5G Filtered BLUE LNBFs
103 West / C-band reception
