Anyone heard if something is in the works? Thanks
Frankly I wouldn't need a dedicated app if there was a workaround for using it in the Metro IE. There is a workaround if you use a regular Slingbox, but this doesn't appear to work for Dish Anywhere.I'm sure sling has a lot more resources to dedicate to multiple platforms, they don't do nearly as many things as dish does. It would be a huge investment and high level of effort and resources to create another app for such a relatively small group of users.
I'm sure the reason there isn't a Windows app yet is because of the marketshare and how small it is compared to iOS and Android.
At the very least, I'd like a web based solution for scheduling recordings, for those "oh sh*t" moments.
Are you not able to access dishanywhere.com from your phone browser and set the timers?
Hmm, looks like it might be do-able from that site. I originally tried the dish.sling.com, which didn't work at all. dishanywhere.com looks like it may work, but still is slow and not ideal.
Sounds horrible. I'll stick with my Android.
Wouldn't be problem if Dish made an app.
I bought a Lumia 521 just to play around with ($129, no contract). My Amaze is still my main phone.
I'll say, from being a strong supporter of Android, there is quite a bit that I like about WP8, I like it more than I thought I would.
Limited time offer
