RFD-TV & Rural TV w/ Pansat 9200HD | SatelliteGuys.US
Achebee
106
9
Honduras
I noticed today that RFD TV signal on AMC/1C was gone again...I used my AZBox Premium plus and got Rural TV to come in at 3926/2249..
I went to my Pansat 9200 HD in another room and did a blind scan, rural did not show up..I input all the Data manually including PID's and I get the channel w/ strong signal but no video or audio...just a blank screen
Anyone receiving Rural TV with their Pansat 9200?? I'm using the same settings I have on the AZbox to input into the Pansat to no avail...Is this a 4:2:2 channel or something along those lines??? Thanks in advance for any suggestions, HB
Rural TV does not come in on the Pansat 9200..software issue..which probably never will be fixed..
Thanks Fat...I have the same data on the azboxes... And yes RFD is gone that's why I went looking for rural TV and bumped into the problem with the 9200... Thanks again for a quick reply...HB
Options to have Plarization Linear & Circular signal on C band.
Thanks to all who helped! Got my lower C band sats
