Skysurfer noticed your post from August...If you edit and then later do a blindscan on that sat doesn't it overwrite your edit? Example would be changing a channel name...I'm trying to figure this out myself. On the openbox you used the editor to change channel name etc...then changed the service Id to zero. It saved the info. If you did a blind scan on the sat again your changes remained. The Micro seems to have some strange PIDS and if I edit I can't save my updated info. I can't be the only one having this issue..Blindjust messing around, I figured out one way. Write down the Service ID number, change it to "0" and then all the PID fields open up. edit the PID fields, then change the service ID number back to what it was and presto.
It will clobber it...I tried it..example several things on 99W Caband and PBS on 125W. Edit and it won't accept it..Unless I'm missing something?
Blind
I do not yet know what this means, how to do it, OR what can the SID be safely changed to... I MAY want to do this in the future.To prevent the custom user name from being overwritten change the SID to a different number on the modified channel using a channel editor. This is a technique used for many years and receivers.
Brian, Thanks for the info. Pop, I think Brian is referring to Station Id. I change all my channels in mine to "0" and then it won't save because the PID starts with an 8 in many cases. If I change info to the APID, VPID, PCR shown on many websites...Lyngsat etc, I get video but no audio. Editing stuff in the Micro is similar to the openbox but I'm finding a few things different.
Blind
Blind
Brian, I'm doing this from memory..I think the PBS stuff on 125W is an example. PBS East and West are two that come to mind I believe.Could you PM examples?
Thanks!
Blind
Brian sent you a PM tonight..problem might be solved?Brian, I'm doing this from memory..I think the PBS stuff on 125W is an example. PBS East and West are two that come to mind I believe.
Finding that on some computers the AliEditor Configuration Settings text is incorrectly defaulted to Chip Type=M3329c and prevents the ability to modify the h.264 and displays incorrect audio settings. If your AliEditor Configuration Setting file is changing to this incorrect chipset default and not displaying Chip Type=M3601s follow these steps:
1. In the AliEditor folder open the AliEditor Configuration Settings file
2. Change text: Chip Type=M3601s
3. Save the file
4. Right-Click on the file to open the file Properties
5. Under the General tab, check mark "Read Only"
6. Click on OK to save the file properties setting
This should place the AliEditor software in the correct mode to provide advanced video and audio settings.
dotbatman said:Is there some setting that needs to be changed so that I can insert channels using AliEditor? I've done the M3601s change but the Insert Channel command is still disabled when I right click in the channel list.
Have you selected the transponder that you wish to add the channel to? If you only have selected the satellite, the Insert Channel option is not available until you select the transponder.
Will pass this on to ALI and request that they provide a new script defining the 99 DiSEqC 1.2 positions in the PC editor.
Thank you!
Limited time offer
