TV Show Season Pass | SatelliteGuys.US
TV Show Season Pass
lacubs
1,596
42
Erie, Pa
every couple month do you need redo them? like last night The Tonight Show & Jimmy Fallon Show was in mine "To Do List" but didn't started recording, anyone know why? Thanks
nope. I've got series timers that have been in mine since February when I got the HR34. Before that I had series timers in mine for almost 2 years with no issues. Lots of shows I record on A&E, History and TruTV are on for a few months then gone until 9 months later or so. Timers are working fine
Do you have a setting wrong? Like to record new and it wasn't?
nope. I've got series timers that have been in mine since February when I got the HR34. Before that I had series timers in mine for almost 2 years with no issues. Lots of shows I record on A&E, History and TruTV are on for a few months then gone until 9 months later or so. Timers are working fine Do you have a setting wrong? Like to record new and it wasn't?
it was the correct setting, i will see what happen tonight
Are you set to Record 1st run, Repeats or Both ...
i have its 1st run, and its had record icon next the show both in mine guide and my "To Do List", but it never came on to record, i did manual last night, let's see what happen tonight
check the history and if it shows cancelled see what it shows as the reason
well, i can't lol at 11:39 i looked at mine HR34 and seen no record light on, so i quickly made sure Jay Leno was in my "To Do List" and yes its was so i canceled it and manual record it last night, so if i go in my history it said (1) canceled by user
Sometime the 1st run thing doesn't work properly, I 'd say 99% of the time it's accurate though.
I currently have ALL my shows set to Record 1st runs only, however my Recordings of Haven show that there is a Saturday recording upcoming that looks like it will record, for some reason, 1st time I've seen it do that in a LONG time.
cancelled by user means you cancelled the timer
Note if you cancel the timer then set one back up it will show in history twice
If it was cancelled by an update or higher priority it will say that as the reason
the only reason i canceled it, i could tell at like 11:40 its wasn't recording, so i freak out and did manual record, now i wish let go and see what would have happen, last night its recorded fine
3 new markets launched in HD today
Discounts for the asking
