Cannot add a channel I subscribe to to Favorites?! | SatelliteGuys.US
typer922
11
Corpus Christi
I went to my favorite channels and noticed that my local Fox affiliate was not in my list anymore. I went into the settings and edited my favorite channels and made sure I saved before I exited. Then I went back into the guide and Fox was still not there. In the guide when I change it to All Channels and even My HD Channels, it shows up. So then I tried saving both the HD and SD channels and the SD saved but the HD will not. PTAT also records the Fox affiliate in HD. Anyone know what's up?
This bug has been around since the beginning. The workaround is to add at least 2 channels.
Glad I found this, the bug is pissing me off. Two days two problems.
So are you saying the solution is to check the one it wont let me add that I want, plus another random one, and then save and that will fix it?
L755 on 722K
