There is no ATSC or QAM output from a Dish receiver, so you're looking at standard def NTSC capture out the s-video, composite, or modulated RF output in descending order of quality. I don't think a component USB tuner exists, but I may be wrong on that.
Thanks for the info guys.Wouldn't the coax out work in sd?
The bigger question is could you be happy with the result?Wouldn't the coax out work in sd?
Computerly devices are typically merciless about how they present SD video. They usually don't go to nearly the trouble to provide careful scaling and smoothing that even the cheapest TVs do.
As time goes on, NTSC support in these tuners will likely disappear if it isn't already.
You probably can, but the question of quality remains. You could drive a car with no seats or windows but it would be far from ideal in the long term.Well what I was thinking was being able to use the tuner with a laptop for signal tuning.
Limited time offer
