Invaldi LNB type - what are the default settings | SatelliteGuys.US
skysurfer
1,737
42
As you cycle through the LNB types, there is one called "Invaldi LNB Type" What is the LNB LO and default scanning range for that LNB type or does it just says "unavailable" if you try to use it?
It is an internal testing position that is removed for distribution. The door was left partially open on current version firmware and a ghost was left behind. ;)
MicroHD Sensibility
Possible bug MicroHD
