Likes System Work Being Done | Page 3 | SatelliteGuys.US
Not open for further replies.
I may be able to adjust the colors that is something I didn't touch.
I am going to leave things the way they are now because I am on my way to Rhode Island for our annual summer family party. :)
Enjoy yourself & spend time with your family. I'd wait till you go back to work when you're actually on the clock. :)
Enjoy your vacation with your family you deserve it Scott :)
Does anyone think that "Like" and "Thank" are redundant ? Either one makes the point clear to the poster and others who see that you like/thank the post.
I do not like the double bar between posts. Is there a way to get the like list in the post sort of like it used to be?
Maybe someway to eliminate a 0/0/0 bar and only show the second bar if there is a like?
I suggested the same things in the other thread about the updates...
I also wonder if the dislike is really going to be abused. It could spark a heated war in some threads (imagine the AMC thread).
Abused may not be the best word... I have no doubt it will be a game for many though and we'll also see "ganging up" on certain members ;)
If I agree with something you said, I'll 'Like' your post. If I ask a question about a problem I'm having and you give me the answer to resolve that problem, I'll 'Thank' your post....
This whole "like" situation has officially earned the eurosport "triple facepalm award"
:facepalm :facepalm :facepalm :D
Sent from my DROIDX using SatelliteGuys
There's (2) bars - one that has the actual, clickable links for like, thank, and dislike. That one I know isn't available to the user -- you can't like, thank, or dislike your own post. Makes sense.
I'm referring to the "status", the one that tells you if your post has likes, thanks, or dislikes. Others have indicated they can see this on their posts.
If one of your posts hasn't had any feedback, you won't see the status bar for your posts. Once someone clicks one of your posts, you should see it. Check your post above mine here, do you see it now?
Nope, nothing shows up. Reason I asked a bit ago was I had a notification of receiving a "like" and checked what particular post it was. Clicking the link takes you directly to the post in question, but there's no status 'bar'.
Here's a screenshot of my post that you liked or thanked (unless you un-liked it or un-thanked it). As you'll see, the status bar is nowhere to be seen.
More SatelliteGuys Stats
Offsite Links
