I re-organized my sats, using the Ali editor, and it works fine, after reloading. The MediaBox editor just crashes with the error n9 , as previously reported by several others.
Ice, where is the "channel change" option located?
Tried to import the satellite list on Mediabox from the MicroHD and I get a ErrorN.9, Subscript out of range! message. It gets stuck in a loop and you have to kill the program.
See posts #23 & #44I'm getting the same error as digiblur. The file I tried Importing is userdb.udf
DRCars said:Is there any way to access the MicroHD directly to download files to computer then upload edited files back to it?
I have a USB (Male A to Male A) cable to hook to the MicroHD from the computer (Windows 7) but what program should be ran on the computer to access the MicroHD?
DRCars
I suppose from all the attention I got from my stupid question that I should set on my tongue and listen! FROM NOW ON THAT IS WHAT I WILL DO!
Is there a tutorial for the mediaeditor program or a faq?
Limited time offer
