Any clue why two ethernet jacks | SatelliteGuys.US
greglwood
29
Any clue why the hopper might have two ethernet ports. I would love it if both could be used, one to access the internet and the other your local lan. I don't have the greatest internet bandwitch and would get two connections if i could figure out a way to make the hopper use one for on-demand but would like it to use other for sling when i am at home.
When you're at home Sling uses your LAN to stream the video.
You missed my point entirely. If i got a 2nd dsl connection and hooked it to the hopper and left my 1st dsl connection hooked to my home lan (iphones, ipads, computers, tv's, printers, etc), the hopper and my lan would be connected only by the internet. Thus if i was sitting in my house and used my ipad to access hopper it would not be going over my lan as it would not be hooked ot my lan, unless it was via the 2nd ethernet port.
navychop said:
I think that would confuse the Hopper system.
I agree. I really was not expecting this to work, but was wondering what the designers had in mind when they decided to put two Ethernet jacks on the box.
It was supposed to be used for a passthrough. So if you only had one ethernet connection in a room you could plug it in to the Hopper yet still have a free ethernet connection to hook to comething else.
Ah, thank you.
You could use something like this:
http://www.amazon.com/dp/B003UT69IK/?tag=satell01-20
I have a company paid DSL line I use with my home Cable modem and it works really well. Cable line is 100 MPBS and the DSL is 20; it is nice to have the redundancy when one drops, and the added bandwidth when they are both online.
Note: this will not combine connections so your speed test will only be as fast as the fastest WAN connection in my case the cable line.
Sent from my iPad using SatelliteGuys
Amazon.com: Netgear FVS336G ProSafe Dual WAN Gigabit Firewall with SSL & IPSec VPN: Electronics
Sent from my iPad using SatelliteGuys[/QUOTE
Well i have a need for this at my office, its perfect. Not sure about use at home with the hopper. right idea if i can find a way to make the hopper go over one line and everything else go over another. I am going to get one of these for my office and see exactly what all it can do.
Netgear makes some good multi-WAN routers. The FVS336G as previously mentioned has two, and the SRX5308 has four. Load balanced or redundant, and you can setup rules for what goes where, if you like. For a bit more money plus a recurring subscription, you can get the UTM series which basically work the same but include malware protection.
Their business-class stuff also has a lifetime warranty.
L711 on 622; What's new?
