Joey mounting | SatelliteGuys.US
Joey mounting
johnny58259
190
Hey just wondering can you mount the joeys behind a flat screen on the wall like you can the h24 h25 receiver with directv
Hi. I can not figure out how to start a new thread, so I am Hi jacking this one.
I am finally getting a my 2H 0J system for my RV on Thursday.
I need some help. I currently have a Motosat dpp 500+ dish and 2 VIP 722K receivers.
I have one cable to each 722k connected through a splitter for each.
Is there a way I can connect the dual node with one cable and a splitter then on the the two Hoppers from the dual node?
I know I will still not get sat 129.
Can I add a separate LNB on my current dish to get sat 129?
Bob
Bob
You will need to go with a western arc single dish solution feeding three lines to the duo node. Come to grips with that and all else will fall into place. The installer should have the equipment to set up the new dish for you.
2 hoppers
Error 36 - Slingbox adapter
