Significantly viewed doesn't apply to satellite in the same way that it applies to CATV. Significantly viewed is something the station has to earn, you can't just fill out an application.I'm wanting to know if they could apply for a "significantly-viewed" station in our state?
I live in Clay County, NC, just over the GA border. For both Dish and DirectTV, we are in the Atlanta market. That means we get no in-state channels and so do not get state news or election results. I am having a very difficult time finding out why we can't get these stations. Who determines this? Who put us in the Atlanta market? I'm told it has to do with FCC regulations, but I am writing an article on this topic for our local paper and need a better explanation than that. Please help.
Yeah have installed both Directv and Dish for years and yes people have tried but no one got anywhere that I have known about.
So do you work for the Clay County Progress?
. I'm wanting to know if they could apply for a "significantly-viewed" station in our state?
yeah the map of NC is really goofy...lots of counties with out of state loclas
That map is actually incorrect for Avery County.The southern portion nearest to the Mitchell line gets Greenville/Spartanburg dma.The rest get Charlotte.
They really need to re-evaluate these zips and dmas.There are parts of Avery Mitchell and Watauga counties close to the TN border that always relied on WCYB out of Bristol for the weather.The local cable company carries both the Tri Cities and Cha locals.The southern tip of of Avery has no cable,there are transponders in Spruce Pine just across the county line that makes getting Greenville/Spartanburg fairly easy with a good antenna.Watauga used to be part of the Greensboro/High Point dma.So to say it's all screwed up is an understatement.
It is not done by zip code by by county. It is also different rules from cable. The rule is which stations most households watch in the county. It is the big 4 cumulative. So, essentially a highly populated section of a county can set the TV viewing for the rest of the county no matter if the rest of the county gets a different DMA OTA.
This is how cable has a lot of influence. If they bring in stations that are watched more than the OTA ones, the ones they bring in could make the county go with the brought in ones vs the OTA ones. It is also really hard to move to another DMA since cable and satellite are essentially dominated by the assigned DMA, and there are not enough OTA viewers to tip the balance.
I think if you look closely you'll find that the DMA boundaries are determined not by what stations are popular but where you're most likely to shop for goods and services.The rule is which stations most households watch in the county.
This is NOT the case. There must be transponders in an area for cable to carry the signal.This strange DMA system was mainly fueled by the cable companies.
Cable doesn't "select" stations, they carry the DMA's station and they may carry another DMA's station if there is demand. Cable is not allowed to carry "distant" stations.If a station in a city further away already had facilities to upload signal to cable companies or if it was cheaper than some of the nearer stations, guess who got selected for importing - and here we are today.
Here's your guilty party in the "franchising" of DMAs.There are proposals out there to mandate in-state locals, but NAB is resisting.
This is NOT the case. There must be transponders in an area for cable to carry the signal.Cable doesn't "select" stations, they carry the DMA's station and they may carry another DMA's station if there is demand. Cable is not allowed to carry "distant" stations.Here's your guilty party in the "franchising" of DMAs.
"Distant" has a very special meaning and it doesn't include nearby stations (unless the distant DMA happens to be adjacent to your market). You would be better served to use "adjacent" or "significantly viewed" instead.I don't think it is true that cablke cannot carry anyting outside the DMA.
Limited time offer
