driz said:Looks like 05E4 is the flavor ifthe week. Just announced. Not in the stream just yet.
- via iPhone 4S
is the ce up?
All,except for HR24-300,"announced." 05E4,just not active yet.
Who make the -300, first I've heard of this one.
Going by Firmware Watcher,they listed it.
Force download a national release on one of your receivers(same procedure as forcing a DL of the CE,just outside of the CE hours for download). Check to see if that receiver still has that problem. If it clears it up,then on your other receivers/DVR,go to menu-settings & help-miscellaneous options(if you do not have miscellaneous options,go to Search & Browse,smart search & type in IAMANEDGECUTTER,hit keyword,all,& then done.Now repeat the instructions of going to miscellaneous options). (now let's assume miscellaneous reports shows up now) go to report,hit send,& when the message is sent,come back to this thread,state the problem you are having,& afterwards type in the key that was given you. This way the techs can check to see what is going on. Each of your receivers/dvrs will have a different key,type in the key for each receiver/dvr(that are still on the CE.If you still have the same problem with the receiver you converted to NR,send the same report for it also).Last night's update did not fix my 720p-on-power-up problem. FWIW. Turning the receiver on gets me a resolution of 720p (even though it isn't selected). Changing the channel or starting playback fixes it. I can reproduce this on HR24 and H24's.
Limited time offer
