What did DIRT say when you reported it to them?This isn't just you. I know one of my Hoppers does the same thing, only allowing access to 2 of the 3 tuners at times, and other times showing all in use and allowing switching between all three.
pabeader said:just so i have this straight...
you are trying to use all three tuners at one time, on the "hopper" directly? You can use 1 and 2 but not 3? can you use 1 and 3?
you also mention that the "joey" CAN connect to tuner 3.
how many 'outputs' does a "hopper" have? i think there's only 2, so where would the 3rd stream of data go?
This isn't just you. I know one of my Hoppers does the same thing, only allowing access to 2 of the 3 tuners at times, and other times showing all in use and allowing switching between all three. It shows Tuner 3 as "Available" but changing channels or selecting it doesn't have any affect - just changes the channel on whichever tuner it's already on. I also have signal on all 3 Tuners via Diagnostics, so it's not a line issue. I'm wondering if it's reading "Available" but actually being used in the background for download, or if it's just a bug. Happened on 2.07 and still happening on 2.09.
Edit: Just saw you mentioned in your first post that it reads signal loss on that tuner, which mine doesn't do, so not sure now...but regardless, I do have times - like right now - when I also don't have access to Tuner 3, even though it reads Available.
The way to force Hopper onto the third tuner assuming no Joeys are turned on, Sling is not active and PTAT isn't in progress:
1) record the current show (press Record)
2) change channels and record this show
3) change channels and record this show
Go to Viewing Status and you should see two tuners in "Recording" and the third in "Watching and Recording".
Now you can select any of the tuners to verify proper signal from the Viewing Status screen.
If a tuner is being used for guide, other updates or for Sling use, Viewing Status will indicate this.
If PIP has been used, you will probably see two tuners in use for Watching (or Watching and Recording).
So I'm confused, the OP wants all 3 tuners to be actively showing while not recording and no Joey's turned on?
If not, then sounds like hopper is working as intended. Only only see two scenarios you would need more than 2 tuners active without a Joey.
A) Recording 2 programs, watching another live TV
1) Put on channel, press record
2) Change channel, press record
3) Change channel
B) Recording 1 program, using pip
2) Change channel, press pip
3) Press swap, change channel
All 3 tuners cannot be in use unless you are atleast recording one thing. The receiver still considers tuners 1 and 2 as the pip tuners even if they're recording, unless you actively engage pip and change channels.
3) Change channel
Limited time offer
