brad1138 SatelliteGuys Pro Original poster Mar 20, 2006 1,218 387 Red Dwarf Apr 16, 2012 #1 The Joeys seem to turn themselves off after just 2 hours or so. I can't find a setting for it. All other Dish receivers are settable for 4-8 hours. Anyone know where the setting is?
rglore Pub Member / Supporter Pub Member / Supporter Mar 12, 2006 1,653 94 Louisville Apr 16, 2012 #2 Go to settings, diagnostics, updates.
brad1138 SatelliteGuys Pro Original poster Mar 20, 2006 1,218 387 Red Dwarf Apr 16, 2012 #3 Thanks, I just found it.
gdarwin Supporting Founder Supporting Founder Lifetime Supporter Feb 9, 2005 4,299 113 Lousville, KY Apr 16, 2012 #4 rglore said: Go to settings, diagnostics, updates. Click to expand... Dosent work on a Hopper/Joey....
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,737 29,870 Rohnert Park, CA Apr 16, 2012 #5 It does if you disable it with Menu, Settings, Diagnostics, Updates....
gdarwin Supporting Founder Supporting Founder Lifetime Supporter Feb 9, 2005 4,299 113 Lousville, KY Apr 16, 2012 #6 Bobby said: It does if you disable it with Menu, Settings, Diagnostics, Updates.... Click to expand... Correct. I was thinking about the 1AM reboot timer.
