Hourly Standby Nagging | SatelliteGuys.US
Royal2000H
19
The 2 hour inactivity timeout was too often for my mom so I set it to the max (without disabling) - 8 hours.
Which, by the way, "Software Updates" is not an intuitive place for this.
However, as I was watching TV on the hopper, it asked me every hour, on the hour, if I'd like to turn off the receiver to get updates or click no to keep watching TV.
I would even pause/rewind 2 minutes before getting the message, so it's not inactive. Is there any way to turn this off? Is it coming in a future update?
I got the messages at 1 AM, 2 AM, and 3 AM (at 3 I let it check for updates)... but I cant tell you that it didnt happen at 11 or 12 too because I personally dont watch on the Hopper usually.
The daily update time is set for 1:00am (instead of the usual 3:00am) and there is currently no way to change the time.
Your choices are let it do its update at 1:00am or put up with the message every hour until you do.
So what's the use of the 2, 3, 4, 5, 6, 7, 8 hours, or disabled "updates" setting? I guess one's hardcoded at 1am and the other is inactivity timeout.
Looks like the engineers really want the hopper to get updates, but hopefully this is addressed in a SW/FW update.
They need to allow user-configurable update time, as they do with the VIP's. Or, change the default to 3am or 4am. A lot of people are watching TV at 1am. Of course, people watch at all hours. But, 1am is still popular enough to create inconvenience for many.
Frustration with 2-year deals
Should I upgrade to hopper if I only have 1 HDTV for now?
