no signal | SatelliteGuys.US
no signal
msrebel
98
I moved in house with slimline 3swm dish I hooked up my h20 receiver and have no signal. I tried with bband converter and without bband and still no signal. Do I need bband or not?
It sounds like you don't have the power inserter installed. Like HIFI says, you need it but you don't need the b band converters. Are you certain it's a SWM lnb?
Does an H20 work with the SWM ?
I don't remember, it's been too long since I've used one.
I know the HR20's do, but did the H20 ?
Used DirectTV receivers
Slimline 3 (99/101/103) with Zinwell 4x4 switch
