2 C Band LNB 2 degrees apart | SatelliteGuys.US
carlospr43
967
12
US
Does anyone knows if taping 2 c band LNBs together can do 2 degres apart??? I'm planning to get 103W and 105W doing some rework on the plates. This is on my SAM I 12 footer fixed, thanks
tried it with my 8' unimesh, it gets 103 and 107 instead.
on my 10' unimesh, i do get 40.5w and 43w with excellent results.
Sounds interesting!
Are you talking about lnbfs? BSC621; DMX741; ESX521; ESX522?
Were the 2 LNBs taped side by side close enough? or you just placed the scalar plates together side y side?? The scalars need to be modify when taping both LNBs together. I have one LNB in the oposite way with the scalar plates side by side and it give me 97W (using 103W as main), so that will be 6 degrees. So I'm assuming that modifying 2 plates so 2 LNBs can be taped together side by side will give me close to the 2 degrees I need to get 105W.
here is a photo of my 103W main with 97W (plates side by side)
Sounds interesting!
using bandstacked, can flip one upside down and then they are right next to each other.
eagle aspen b1sat c-band stacked lnb.
carlospr,
i machined the slot to go just to the other lnb.
I think ice made a mod that actually had the lnbs touching.
here is a pic of the unimesh with it. this LNb came with nice beefy scalars that could take a beating.
Nothing glamorous, just bolted it in and tried it. all attempts to add a scalar to the outer lnb, failed.
you are showing a greater distance then i have with my 97 /103 /107 combo. maybe cause you have a 10'er?
I would try it if i were you.
I also want 105 real bad, but i may have to add another bud to get it.
edit ;with the search skills of a lesser Anole
i found one of the old posts, here is it
http://www.satelliteguys.us/c-band-satellite-discussion/92274-2-c-band-lnbs-one-6-a.html
How about park the dish half way between the two. I did this by accident today and was getting all tp's on 101 and 103 in both sat lists.
i might give that a try, but since i already have a dish with a lnb at 107 and 103, i will be attempting 101/103,105/107.
boy is this weekend going to be fun!
How do I know when I need to replace the LNBF?
Coolsat 8000 power supply problem
