dish network on prime focus dish 2.4 meters dish pro lnb single | SatelliteGuys.US
119 IMG-20120117-00003.jpgIMG-20120123-00307.jpgIMG-20120123-00308.jpgIMG-20120123-00309.jpgIMG-20120123-00310.jpgIMG-20120123-00311.jpgIMG-20120123-00312.jpg
Prime focus is hurting you. the strongest part of the signal is being blocked by the lnb itself. You would get better signal with Parabolic dish of the same size. Additionally, prime focus dish is not designed for the smaller feedhorn in a dish lnb. your lnb may only be getting signal from center section of the dish. not getting benefit of the full 2.4 meters. Where is the dish located?
722k with 2 external drives
Refurb?
