Direct tv swm | SatelliteGuys.US
Direct tv swm
Tanner123
I have a direct TV swm with h24 receiver. The receiver, power inserter and 2-way splinter are 500' away from the dish. Is there an in line amplifier that can be used as I do not get a signal from the dish.
Hi . I'm going to move this to the directv forum so you can get help there.Welcome to the site!
Is there any reason why its that far!? If not, MOVE IT! If you can't move it you can try getting a 29 volt power supply. I've seen them used in problems like these. The LNB is normally the first to go though. You can also ditch the switch. You're loosing half a volt and 2 Db's right there. You can also try getting a regular LNB3 or 5. 500ft is pushing it with that but it's more likely to work
:welcome to Satelliteguys!
As others have said, moving the dish closer would be a big help if you can, as would removing the splitter. Another possibility is to replace the cable with RG11, a heavier gauge cable.
Showtime VOD - Dexter Season 6. Partial episodes???
Moving from Comcast need advice
