Shaw/Starchoice Switches? | SatelliteGuys.US
no
Shaw uses the same switches in most cases as Directv and Free to air like 4x8 multiswitches and 22k switches
Bell uses the same switches as Dish does
no
so you can use diseqc switches?
how does the dual shaw lnb work? do you need two cables out of it for each receiver? is it basically two lnbs in one housing?
Yes it is two LNB's in a single housing, set for a four-degree-satellite-spacing. It has the ability to switch from one side of the LNB to the other based on a tone sent from the receiver.
There are two models of LNB that match the model of the dish: the 60e LNB must be used with the 60E dish; the 75e LNB must be used with the 75e dish. They are not interchangeable
You need one cable for each tuner. If you have a PVR (DRS530 or DSR630) containing 2 tuners, 2 coax cables are required for that receiver. Otherwise, a single cable is required per receiver. Each of the four outputs on the LNB is identical.
Shaw/Starchoice Install
No Go Shaw Direct on 100cm dish
