H2x & HR2x for the Weekend of 12.16 | Page 6 | SatelliteGuys.US
I just wanted to report an issue with the CE from 12/16. It works fine on my HD-DVRs with zero issues, however, the version on my H21-200 causes issues after having it installed for 2 days. When you turn the receiver off and turn it on, it says "searching for satellite signal". The only way to fix it is to RBR. Then, you'll have good signal, picture, etc., until you turn the receiver off. The next time you turn it on, it'll say searching for satellite signal while displaying a frozen frame from whatever show was on at the time you turned it off. I reverted back to the national release, and the receiver works normally again. Unfortunately, I didn't have an ethernet connection hooked to it to upload a report.
For those of you that haven't gotten Pandora or Youtube, have you entered IAMANEDGECUTTER into the search function? That may get it for you.
HR34 CE Release 12/23
Just installed the new HR24 HD Gui, and it's painfully slow!!!
