So the big question is - what size dish should I consider? I like on a farm so I can get any size I want.
Well then by all means get a 10 ft to use on C band. Although a 7.5 or 8 ft work well also. But a 10 is by far the "standard". Some can be used on both the C and Ku band.
OK. As soon as I find you a 10 footer, I'll bring it right over. Cost only $10,398.98Considering FTA and have no limitations
As we all know, the bigger the rack...if you are a hunter, pretend a BUD is the prey and begin road hunting. you will soon have a target, i am sure!
Limited time offer
