Jim,
It means a file that are downloading is a compressed file, you have to uncompress it (Unzip)
I've been playing with MAZ for a couple days now and managed to really mess up my receiver pretty good. I'm starting to have this "Love Hate relationship" with my AZBox.
It doesn't seem to have any kind of channel/guide options that you can use. Is channel selection by channel number entry only?? beside the up/down buttons.
What does unzip mean
Jim,
I would think you could select the channel in the guide screen even without content showing, but it doesn't work that way, bummer. With no favorites or other channel list options, it makes FTA a little more work.
The AZBox definately leaves a lot of room for improvement. I'm probably going to find a different solution for my wife to use.
ACWxRadar:
The DVD trick worked!!!!!!!!!
Thank you and for the Movie Friday
Thank You very much! I'd been looking for that screen and thought it wasn't there because of the FW version. Now we're getting somewhere!Magic,
You can set up a favorite list of channels. That makes things a lot nicer, instead of hundreds of channels to wade through, you only have a few to a dozen on each sat. You can orgainize your fav ch listings any way you like, it is very versatile and works really slick. Read the AZ-Guide and it will inform you of the how-to's.
RADAR
Limited time offer
