So will anybody be fined, or will they have to fix what went wrong and have to pass the next test, that is if another test is given?
Had on NFLN on one TV, local NBC on the other, and neither had the EAS go off. Also, my weather radio is set to go off with an EAS activation, and it did not go off either. I think it was a system failure, not a provider failure.
radio said:NWS was not part of this test.
Well I am hearing from DISH the alert never went off on DISH because they never got the Emergency Alert Signal. Seems as though the entire EAS system uses relays and when one goes out the other systems down the line don't repeat the signal. That's why the EAS didn't go off on DISH.
You can read more about what happened at Emergency Alert System to Be Tested Across the Country's TVs and Radios - NYTimes.com
Actually thinking back DIRECTV kind of cheated a bit on their EAS broadcast, as they switched to a slate about 30 seconds before the actual EAS went off. If it worked like it was supposed to the alert was to kick in when the alert went off. So they kind of jumped the gun there a few moments early. In addition DIRECTV never seemed to have got the audio, instead they played Lady Gaga... so almost looks like they never got the audio feed as well.
So funny I forgot to laugh.I heard that the EAS wanted 40 cents per subscriber to run their test, but Charlie was only willing to pay 39 cents per subscriber, so the test was pulled from Dish!![]()
What about the other 75-80% then ? The # of people with OTA tied into their Dish receivers is really, really small. Don't base how many it seems like use it based on users here...Something I just thought of is that E should just have the units that pick up OTA to trigger the alert in the unit it self. Then the TV would just switch to the local OTA for the majority of the units out there.
As E* moves forward replacing the old receivers then it would be more possible. Yes there will always be some that can't receive OTA but that will be a minority of the over all. This is just something that was a thought that came to me after the failed test.What about the other 75-80% then ? The # of people with OTA tied into their Dish receivers is really, really small. Don't base how many it seems like use it based on users here...
"Can" receive OTA and actually hook up an antenna to their OTA-capable receiver are two vastly different things. Dish CANNOT assure or assume people have it connected to an antenna that they'll rely on for EAS. They can be reasonably certain that people will be connected via satellite though...Yes there will always be some that can't receive OTA but that will be a minority of the over all.
So the Albuquerque CBS station pulled a Directv and aired their "own" EAS Test (which was clearly marked KRQE)...Update received this morning on the problems. Looks like FEMA screwed the pooch.
The regional PEP station didn't receive it from FEMA, so nothing aired in New Mexico; this seems to be the case for a lot of stations in the Western and Southwestern US. The PEP station is doing an RMT today as a backup to ensure our in-state connectivity is still working. As the state EAS Chair, I'm going to have a busy month following up on this.
Mike Snyder, KNME-TV
Most likely they entered it into automation which triggered it to go off.So the Albuquerque CBS station pulled a Directv and aired their "own" EAS Test (which was clearly marked KRQE)...
Limited time offer
