Why 10 points of Quality is so important | SatelliteGuys.US
chapelrun
965
14
Berryville, VA
I had not adjusted my 6 foot Prodelin shown in my AVATAR since I first set it up.
This dish really only exists for one channel - - - INSP - - - and I had only been watching analog.
Then I found this.
http://www.insp.com/wp-content/uploads/2010/10/Tech_Fact_Sheet_INSP_10.19.10.pdf
I changed over to the digital feed which is channel 600 on my Motorola 922 - - - but it would break up a lot and was not watchable. Decided to tweak the dish - - - both the LNB rotation and the elevation and was able to get almost 10 more points of Quality. This made a huge difference and now INSP has a crystal clear digital signal.
One thing I did notice is the analog quality actually went down a bit but the digital quality went up from Q of 41 to a Q of 51. I have not figured out why this might be.
Tweak your dish for the very best signal - - - even a few points can make the difference between watchable and not watchable.
I put a conical scalar on my first 6' Prodelin I put up a few years ago for 4DTV fixed on 105W. It made a pretty big difference with the Motorola receiver on digital. Analog is pretty much watchable with any signal at all, just a few more sparklies in it.
Concur. Tune until your tongue hangs out. Then take a break, and tune some more.
Here, Here
I like this information - - - I assume you used this conical scalar - - - or one similar.
Here's what it looks like when it's uncovered. It's not exactly weatherproof by design since it points slightly upwards. I wish someone would sell a reasonably priced covered C band LNBF for offset dish use.
Here, Here
I cannot understand what OP says about going over to Digital ?????
I have a BUD ( i am new to this and rooky) but I thought I am watching digital signals when I point to 123W with my HD Openbox9.
COuld you please help me to understand this and point to where I can read and learn this "Digital" & Channel 600?
Thanks, Wilson
Signals used to be analog and then about 10 years ago the big push to digital signals begin (for backhauls and feeds).
I used to run 2 analog receivers and then in 2002 I bought my first digital rcvr. Analog signals are almost obsolete now, still a few, but not many and not enough for me to mess with anymore. Your openbox is strictly digital, you need a completely different receiver for analog.
Nice paint job on the dish, Chapel.
My daughter and her two cousins painted it for me. You might have seen it over in the FTA-Shack.
http://www.satelliteguys.us/fta-shack/262542-beautiful-dish-painting.html
This thread might help a bit - - - - not many 24x7 analog feeds left. I have not been into C-Band very long - - - so I don't remember the glory days of analog on C-Band.
http://www.satelliteguys.us/c-band-satellite-discussion/237933-no-analog-channels.html
Do I really need a DVB-S2 receiver at this time?
I have an HTS BUD, want to bring it back from the dead.
