L Leafs99 Well-Known SatelliteGuys Member Original poster Oct 20, 2011 30 0 Seattle Nov 1, 2011 #1 Is there any way to force a full guide refresh for HR24 DVR's? Other than the obvious one of unplugging it
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,153 8,506 NW Ohio - Buckeye Country Nov 1, 2011 #2 Leafs99 said: Is there any way to force a full guide refresh for HR24 DVR's? Other than the obvious one of unplugging it Click to expand... You can do a proper recvr reset, that will reset everything, much like the proper way to shut off your computer. Menu/Settings/ReSet/ReStart Recvr/ dash
ProfStata SatelliteGuys Pro Sep 11, 2003 248 7 West Nov 3, 2011 #3 Don't you have to reset it twice to flush the guide, since the new receivers cache it.
T texasbrit SatelliteGuys Pro Pub Member / Supporter Cutting Edge Apr 12, 2006 3,656 365 Nov 5, 2011 #4 If you are trying to get the new HD GUI, then you can't. It does not start rollout to regular customers until 11/8, and then you will only get it when your receiver is designated for a download. Could be weeks before everyone gets it.
rich584 Member Sep 10, 2007 10 0 Nov 5, 2011 #5 Leafs99 said: Is there any way to force a full guide refresh for HR24 DVR's? Other than the obvious one of unplugging it Click to expand... You have to reboot the HR twice within a half hour to flush the guide data and have new data downloaded. Works well for sluggish HRs of all models. Rich
