522 to 722 installation. Please help! | SatelliteGuys.US
PurpleMilk
2
C-Town
Hey guys! My coworker is currently running a 522 in two rooms via a 1000 dish. Her and her boyfriend just purchased a 722 to replace it.
They aren't super savvy with this kind of thing, so they wanted me to install it for them. Since the 522 is also a duo dvr, would I just simply be able to unplug the cables from the 522 and plug them into the 722 and I'm done?
Any help would be appreciated, thanks!
Yes. You may need to change a couple settings in the receiver to get sat signal and TV2 working, but otherwise the cabling should be the same.
When you connect the 722, run a check switch test
Thank you very much, I appreciate the prompt response!!
I will post back in here if I have any problems. Thanks again.
Super Stations in Hd?
Recorded events disappearing
