Still don't have it here.
Dish maybe having some problems.The last few days I have been up in the early mornings and my 722k/wMT2 does it's 3AM reboot,then later while I'm watching I get the window that pops up saying they need to check my receiver for the latest software updates.I select yes then it does it's thing and afterwards I check it it still has L683.![]()
Just because it is checking for new updates doesn't mean that it will be s/w updates. It will do that every night for guide updates.Dish maybe having some problems.The last few days I have been up in the early mornings and my 722k/wMT2 does it's 3AM reboot,then later while I'm watching I get the window that pops up saying they need to check my receiver for the latest software updates.I select yes then it does it's thing and afterwards I check it it still has L683.![]()
Not really. Even when the notes and things are released, all it will say is "partial release - 100k" or something like that. They don't specify what receiver numbers get it (they spool s/w other ways besides Receiver number sometimes IIRC)
Not sure if anyone mentioned this or not, but when I got 685 it changed my guide format to small text (I was using medium) and set my preferences to HD only. Both of which I had to change. It kept the banner off, that's one good thing.
Other than that the overall response of the receiver seems to have gotten a tad faster, it's almost instantaneous with everything, hope it stays that way. Search history is gone as well.
I wouldn't want to be around if you ever won the lottery!![]()
Aw, don't feel sad. I'm sure you'll get the update... eventually.Still hanging out with L674 on my 722.Still no word on these features coming to my 612's either. :cry:
Limited time offer
