Run atleast 2 coax cables to each location, along with (2) Cat6 Cables.
Here is my house...
New House Photos
Claude, do you have conduit in the walls that the wire is ran thru behind the brick ?
charper1 said:When I did mine back in the day I ran a wiring channel so even if I did have to add more later it was a breeze.
There's absolutely no reason to suffer MoCA if you've already got GigE in place.
Doesn't really matter if most of the DECA connected receivers aren't H(R)24 models, does it?..Except MoCA/DECA is twice as fast as the 10/100 adapters built into the receivers.
Limited time offer
