I suggest avoiding the green series. The black costs a bit more but there will be no spin down problems.
AFAIK, they don't offer any green EHDs.
Hmm... wish I had played with that earlier... though it doesn't apply groups to the EHD.You can set the Sort/Group settings in your "My Recordings (internal storage)" menu and it will apply those settings to the "My Media (EHD)" menu. Also if you set your Group setting to either "Group by Title" or "My Groups" you will get a nice little "My Media" shortcut to your EHD in your DVR menu. Also has the side benefit of grouping your shows together.
Yep. GREAT price, too.
My 1.5 T takes no longer than my 500's.Is it true that the bigger the drive, such as 2TB take forever to load? I only have used 500GB drives and they are slow enough, especially when archiving HD movies. I really don't see why larger capacity EHDs are even slower but that is what I've heard? Does anyone know if that is true? Thanks for that info THeKrell, it must be my two drives have a glitch that will not allow the 612 to recognize them even though they work fine with my 722k.
My problem may be that I almost exclusively put movies on the EHD. I don't save programs, so that may explain why I don't have "groups". Although, now that I think of it, I do have Blue Planet on the EHD. I need to check if that got put into a group.It applies groups to my EHD. You sure about that? Not sure if it works with custom groups though, but it works great for grouping by title...
Limited time offer
