I got my Sling Adapter to work one time showing my DVR recordings. It has not worked since. I can watch live TV. 722 is hooked up via ehternet. Any suggestions??
Seems odd.. but all I need do is connect to my sling adapter, and it forces my 722k into dual mode ... and when not useing it... it stays in dual mode rather than reverting to single.. I thought I also read somewhere that it was supposed to do that.. ie.. force dual mode..Try putting it in dual mode if you're willing. Tony and I messed around with some test receivers a couple months back and we were having similar problems when the 722k was in single mode. We put it in dual mode, and it worked like a charm for us
this all still sounds like an account problem ... just to be clear.. your "My DVR" tab is empty and yet you can still play live tv ...Okay, i got around to testing and even though the dvr is in dual mode, it is not showing the recordings. I do see my conflicts though, which did not show up when it wasnt showing before.
AHHH how we have it..I do not see the server in the url. Im using IE9, that may not show it. And yes i can see live TV.
it won't necessarily solve the problem .. but would make it more visible as to which server you're hitting.Yeah, I was actually going to www.sling.com, letting it redirect to dishonline. I will try that out.
Limited time offer
