HR2x CE Release 4/8 | SatelliteGuys.US
HR2x CE Release 4/8
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
HR24-100 • HR24-200 • HR24-500
Window of opportunity to download:
Friday, April 8, 2011 11:00PM - 2:30AM ET
Saturday, April 9, 2011 11:00PM - 2:30AM ET
Risk Level for this Download:
High Risk
New features
None
Improved/Updated
Fixed bonk on 30skip
fixed freeze during trick play
Under the Hood
Known issue
VOD downloaded with a previous CE will be deleted by this CE
Notes
This CE may remove your guide cache if you did not download a previous CE. Please allow up to 24 hrs to restore your full 14 day guide.
You will lose your guide cache when reverting from CE to national.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:26:01(0x046B)
Enhanced Channel Banner!
Improved/Updated
CE:26:11 (0x048F)
Trickplay bar
Esata issues
Any word as to if they are gonna fix the software so that when I finish watching a Recorded show, I go back to the channel that was on and theres actually a PICTURE ?
Been dealing with this issue for about a month now.
If you change channel, the picture comes back.
I have an issue with that I cant add anymore timers in the series manager to record new shows, it says it is full even though I have deleted other timers. HR-23/700
HR21-200: Latest update causing general weirdness with FF, Rewind, blackouts, slow response
The last two updates I've done, including this one, have made the HR21-200 really unstable with basic functions: fast forward, rewind, pause, even signal stability. We get picture drop outs while the audio continue. I'll have to reset to the national release again.
Please Send Logs
HR20 thru HR24 CE Release 4/15
