Which receiver is which? | SatelliteGuys.US
CK SatGuy
Formerly ckhalil18
4,023
112
The Motor City
Okay guys, I have another question for you. Here we have two receivers. Which one is a 301 and which one is a 311? I put the pictures in a doc to hide the picture captions.:)
I'm not sure either one is a 301. I just dumped a 301 that I replaced with a 211. The 301 I had had a flat front end......
There is normally a bar code tag on the back of the receiver and it will list the model # (DP311 or DP301).
Top one is a 301 bottom is a 311...trick question
301 always had a pull out card
311 until N3 didnt...and even some refurbs have the card built in
side note...the only other difference cosmetically is on the cover where the card goes
301 says
DP301
whereas the 311 says "311" on one side of the flap and "DP" on the other side
311 has 8PSK tuning while the 301 does not
211 works, but 722 don't?
Bloomberg TV HD
